I have a 04 f350 with a 7 inch lift. I normally have 37 inch mud tires on but needed good winters put on, on short notice and my budget was about 2 grand. Ford service dept. put on new winters which are 33's and said they'd be good. Ever since, the front tires were rubbing especially when I made sharp turns. Brought it to a diesel shop a couple days later for some other work and they noted "front tires are rubbing on leaf spring because they are the wrong offset wheel for this truck". Ford is saying it isn't their problem because its the lift that's causing this and insisting the same thing was happening with the summer tires on and that they put on the proper tires. I'm certain there was no rubbing with the summer tires on. Diesel shop said it needs "spacers" put in. Ford said I should take it to a tire shop to have "steering stops" put in. Ford never mentioned that this would be an issue and if they had I would have done something else, gone with different tires from the start or had them complete the job with the steering stops. Am I wrong and completely misunderstanding what is going on here? Just hoping for some opinions. Thanks! 😊
