1 - 20 of 28 Posts
Vendor
Ford F-250 / F-350 Super Duty Switchback LED
At Diode Dynamics, we carry a full line of LED bulbs, including these unique dual-color switchback LEDs! Our HP24 is a brand new design, and the brightest available on the market, designed by our engineering team in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Your purchase includes two 3157-size turn signal bulbs, for perfect fitment in all Ford F-250 / F-350 models.
Resistors, as mentioned in the video, are required to prevent hyperflash.
This includes a pair of front turn signal bulbs which are "switchback," a unique, specialty design. When this bulb is on as normal, with your parking lights or headlights, it shines a nice, pure white color. Anytime you activate the turn signals, it flashes bright amber. Two colors in one bulb, for an awesome lighting effect! They also won't produce an amber tint inside the housing when the bulb is off, for a much cleaner look!
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means we use only brand-name suppliers, and we tightly control color temperatures with our in-house testing equipment. One sign of low-grade LEDs is a very blue color tone, or mismatched bulbs. Our LEDs will always be uniform in color, with bright whites, rather than sharp blues.
Design. Although LED technology allows for extremely long bulb life, the market is flooded with cheap, generic LED bulbs that fail prematurely due to inferior design and construction. Even bulbs from reputable suppliers are simply standard designs from Asia. They may work, but they are not designed with automotive circuits and applications in mind, so they will always fail within a few years of use.
At Diode Dynamics, we specialize only in lighting, so we have invested in developing quality products. Our engineering team designs bulbs to withstand the harsh automotive environments, both electrically and physically. Our bulbs will distribute light more evenly than standard "tower" designs, and they will last much longer than simple LEDs, powered by basic, cheap circuitry. By using advanced, LED-specific integrated regulation circuits in our bulbs, they are designed to last for years to come.
Off-brand, cheap bulbs also exhibit poor construction quality, as they are often hand-assembled. Quality control is often lax, as the poor construction really won't be noticeable until a bulb fails after only a few months of use. However, common visible problems include poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires and terminal alignment, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing. Diode Dynamics bulbs will not exhibit these problems, as they are assembled with much more rigorous standards of quality control, with modern, computerized equipment, and only the best materials, to ensure the highest levels of quality and performance possible.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
Doesn't Even Care
Will we need to put the resistor in to make them work properly with my 99 truck?
Vendor
You will need to install a replacement LED flasher unit or install resistors to prevent hyperflashing from occurring
If you have any questions about installation, please feel free to give us a call: (314) 205-3033
The Switchbacks are a great looking upgrade and one of my personal favorites
Thanks!
Nick C.
When will the white ones be in stock for the 2011+ trucks? On the site it says they're on backorder..
Reactions: Brunomarcs
Vendor
Discussion Starter #8 (Edited)
I want the pure white, I didn't see them listed?
EDIT: They aren't a option in the drop down menu's I just checked..
Reactions: Diode Dynamics
Waiting on a response on how to get the 5k switchback/turnsignal lights as it's not on your website.
Do you have sample pictures showing the different color temperatures? I like the cool white but what I hate more than anything is whites that don't match the rest of the truck...
Also, your site says the 4000k and 5000k are both sold out at the moment, is this true?
Vendor
Discussion Starter #17
6000K is all that we are currently offering. We may offer 4000K & 5000K again in the future, but I don't have an ETA available for them.
Keep in mind, our color temperatures are actual measurements, so other 6000K products from us will be a close match
Nick C.
1 - 20 of 28 Posts
