These instructions are horrible. Is drilling required on a 2010 F350? Or do I simply throw some screws into existing holes? I don't mind drilling, but not if it's unnecessary. Thanks.
Assuming a SRW truck and the flaps are the same as the 2009 ones, no holes in the front, upper and lower holes need drilled in the rear.
i picked up a pair of the checker plate ones from ford. on these you use the existing holes, but there must be one extra one drilled (front and rear). i had to pick up a right angle attachment for my drill since it looks kinda tight. this weekends project..................................
