1 - 16 of 16 Posts
I don't own a 7.3. ...but while I was looking for some information on my 6.0, I ran across an electronic copy of a 7.3 PC/ED. I didn't even know that there was a 7.3 PC/ED.
Previously I have posted copies of the 6.0L and 6.4L PC/EDs. That's because PC/EDs are the best. For those unfamiliar with them, I have described them like this:
You know that one time when your brother was really drunk and he told you A) there is a Brake Pressure Applied switch on your 6.0 and B) how to effectively troubleshoot it? That came from the PC/ED.
Remember that other time when your great uncle - on his death bed - told you how to do a KAM reset? That also... well... you get the idea.
Here is a qualification statement with regard to this post:
  • I believe that this document to be out of print and able to be posted without issue. If you are overly squeamish in a copyright sense, do not so much as cast your eyes in the direction of these documents.
  • The PC/ED is for the MY1998-99. Use your brain if your 7.3 is not a MY1998-99. In fact, use your brain, regardless.
Here is the full document list:
1998-99 PCED 73 Section 0 - Introduction - 1 of 1.pdf
1998-99 PCED 73 Section 1 - Description and Operation - 1 of 1.pdf
1998-99 PCED 73 Section 2 - Diagnostic Methods - 1 of 1.pdf
1998-99 PCED 73 Section 3 - Symptom Charts - 1 of 1.pdf
1998-99 PCED 73 Section 4 - Diagnostic Subroutines - 1 of 4.pdf
1998-99 PCED 73 Section 4 - Diagnostic Subroutines - 2 of 4.pdf
1998-99 PCED 73 Section 4 - Diagnostic Subroutines - 3 of 4.pdf
1998-99 PCED 73 Section 4 - Diagnostic Subroutines - 4 of 4.pdf
1998-99 PCED 73 Section 5 - Pinpoint Tests - 1 of 5.pdf
1998-99 PCED 73 Section 5 - Pinpoint Tests - 2 of 5.pdf
1998-99 PCED 73 Section 5 - Pinpoint Tests - 3 of 5.pdf
1998-99 PCED 73 Section 5 - Pinpoint Tests - 4 of 5.pdf
1998-99 PCED 73 Section 5 - Pinpoint Tests - 5 of 5.pdf
1998-99 PCED 73 Section 6 - Reference Values - 1 of 1.pdf
1998-99 PCED 73 Section 7 - Metrics and Index - 1 of 1.pdf
I may have to truncate file names as I am uploading.
Because the forum only allows (5) attachments per post, this will take a few posts to complete. Be patient. ...and - to keep things together - I'd prefer if any posts from others could wait until the last document goes up.
Enjoy!
Discussion Starter #2
Attached are the introduction, overview, and symptom descriptions...
Please note that there are some blank pages in the documents. They seem to be extra. Regardless, it is what it is. :)
Reactions: tmplangel
Attached are the hard start/no start diagnostic procedures and DTC code references to the Pinpoint Tests...
Attached are all of the Pinpoint Tests...
Attached are the reference values, torque chart, and index...
Discussion Starter #6 (Edited)
This is some free market right here! Thank you.
Reactions: djmaguire
I thought that I'd bump this. No reason other than it's hardly been viewed. Seems a shame if someone could be helped by it, but nobody knows about it. Hell, I didn't even know it existed until the day I posted it. Lol.
Sticky, maybe?
This should be a sticky. Mods put down the eggnog.
gold mine of information
Thank you for posting this trove of technical information. It is a great help as I transition from working on sports cars to the 7.3 L PSD.
Discussion Starter #12
I just noticed while looking for something else that not many people have seen this. Just giving it a bump.
It would get more views in the section relevant to the model years involved. Do you by any chance have the PCEDs for any of the OBS model years?
Discussion Starter #14
Well, it kinda is... The PC/ED is dated as 98-99. All of the electrical diagrams are 97. The forums are 94-98 and 99-03. I picked the earlier.
I do not have a PC/ED for the OBS years and have not run across one. I will certainly keep an eye out for it and let you know if I get a hit.
'98 is only referenced here for the vans. I'm guessing this is a truck PCED.
Yeah, if you find one for OBS, that would be awesome. Even the paper ones are hard to find, and when they do show up on eBay, they're $$$$$.
Discussion Starter #16 (Edited)
I didn't think that the PC/EDs were very truck or van specific. That said... maybe a mod can do the move to the later forum. ...and make it a sticky to make it easier to locate.
Got it to the OBS PC/EDs. I'll def keep an eye out.
_______________________________________
Edited to add...
@madpogue... I should have said, "Before *this* one, I didn't think that the PC/EDs were very truck or van specific." I do see that this document very clearly makes that distinction. What I was trying to say is that - based on the other PC/EDs that I have run across, this is the first one making that distinction.
Thanks again!
1 - 16 of 16 Posts
