1 - 8 of 8 Posts
current DTCs
P0266 cylinder 2 Injector Circuit Contribution / Balance Fault
P0278 cylinder 6 Injector Circuit Contribution / Balance Fault
P1102 Mass Air Flow Sensor In Range But lower than expected
live data meter readings: AT IDLE
ICP: 589.74
INJECTOR CONTROL PRESSURE REGULATOR: 26.95%
INJECTOR CONTROL PRESSURE VOLTS: .90V
BATTERY POSITIVE VOLTAGE: 13.50
MASS AIR FLOW VOLTS: .09V
EXHAUST BACK PRESSURE 1.24 V
ENGINE OIL TEMP: 225.50
FUEL LEVEL INPUT: .50V
TRUCK HAS A LONG CRANK TO START COLD AND HOT
ROUGH IDLE
BOGS DOWN WITH ANY STRAIN ON MOTOR CUTTING STEERING WHEEL OR DEPRESSING BRAKE PEDAL
ACCELERATES IN PARK AND NEUTRAL REVS UP FINE ROUGH LIKE ITS MISSING
AS SOON AS YOU THROW INTO REVERSE AND OR DRIVE IT DIES DOWN
AND EVENTUALLY STALLS OUT
I HAVE CHANGED THE ICP SENSOR BRAND NEW
CHANGED IPR VALVE BRAND NEW
CHANGED TURBO BRAND NEW
CHANGED FUEL FILTERS AND HFCM BRAND NEW
NEW MOTORCRAFT OIL FILTER AND 15W-30 ROTELLA MOTOR OIL
MANUALLY CHECKED WITH LIQUID FILLED GAUGE OIL PRESSURE AT ICP PORT READ 800 PSI AT IDLE AND HOLDS REV THE MOTOR GOES TO 2,500 PSI
CHANGED 4 INJECTORS ON PASSENGER SIDE WITH BRAND NEW INJECTORS
clean your mass air flow for a start. just wet a tissue and rub the resistors on there. be careful though, they are fragile.
My mass it flow is not even plugged in to anything the air box I have doesn't have a connector
And would the mass air flow really cause the truck to stall out and not have any power to drive passed idle with my foot on the pedal to the floor
yeah. you will have all kinds of throttle issues without it. your truck needs to know how much air is coming in so it can match the proper amount of fuel and all that. but if its been like that the whole time maybe its not your sole issue.
hmmm fuel starvation? dying when you turn the wheel or depress the brake is because you are using your power steering pump, which strains the motor. it sounds like low icp or low fuel pressure. im assuming low fuel pressure because it doesn't have any codes for icp...
1 - 8 of 8 Posts
