Ever since i bought my truck the foglights have not worked on it!! I'd love to get them working, but im not sure what the problem is.
I've already tried replacing the fuses, and i swapped in a new bulb to see if it was the problem, but no dice.
First off, to turn them on i simply just turn my headlight knob to the cab lights or headlights and they should be on correct?
Any ideas or thoughts on what the problem could be would be very thankful.
BTW, why did they make it so its so damn hard to remove the bulbs!!!
after turning the headlights on you have to pull the knob out to turn on the fogs. you should see a fog light symbol light up
Right and they only come on with low beams.
Duhhhhh, facepalm!! :doh::doh::doh:
But to my defense b4 when i tried that the knob just pulls off on me. I just glued the knob on and that should cure my problem.
Thanks fellas. hahaha
