I got a BTS transmission back in 2009. I have put about 80,000 mile since then. About 6 months ago I was getting a lot of noise when idling or when costing. I was told it sounded like a cracked/broken flex plate. I took the truck to my local Diesel shop. It was the flex plate; it was broken into two pieces. One piece was attached to the crank while the outer piece was attached to the torque converter. It was driving the trans because of the shape of the crack.
Well about a month ago I started hearing a noise only when truck is first put in reverse after sitting. I have the truck back a at the diesel shop for something else and asked him to look at the noise.
He called me today too tell me the flex plate is “moving” and hitting the starter. He wasn’t sure why, he said if it was some related to the work they performed, they would take care of it. But said it could be the transmission pump or the crank moving. I don’t see how it could be either.
Has any one seen anything like this? It's a 2002 CCSWB F-350 7.3/automatic.
