1 - 20 of 22 Posts
If you have the 4 post FICM (remove little cover on top below are 4 or 7 screws). I do not know if this works for 7 screw ficm. Check the voltage on the screw closest to the fender and ground if less than 45 volts engine running you can repair it yourself and no reprogramming needed (dont touch probe from screw to the case).
Remove FICM from truck. Remove the following; small cover on top of ficm, 4 screws that are under cover, 6 screw on other side holding case together. Split case. Re solder 16 places circled in pics. Put back together and check voltage.
Bad solder only on those circled connections?
Do you need to de-solder them before you resolder them?
Well I guess if you have a bad FICM anyway what do you have to lose?
hell yeah, what do the new FICMs cost? 300-400 bucks? I'd try this in a heartbeat.
Probably a good idea!
This is great. What a way to save a lot of money.
Discussion Starter #19 (Edited)
The pic. with the small circles are resistors, so both sides need to be soldered (be carefull and do not solder the resistors together). The pic. with the large circles have 4 places in each one.
1 - 20 of 22 Posts
