Hello everyone, I recently bought my first diesel; an 06 f250 6.0.
The good:
It came with ARP studs, EGR delete, SCT live wire, kc jet fire stage 2, 30% 155? Injectors WDI I believe and s&b cold air intake. These I was able to verify, not sure about anything else.
The troubles:
At first, I noticed my coolant temp and oil temp were 35+ degrees difference. No biggie warranty service covered parts and labor for an upgraded cooler, new thermostat and I paid for a coolant flush, oil change and some new tunes.
First weekend I got it back I decided to pull the camper to a pretty close by camping spot (~30 miles) blew boots 3 times hot side ICx1 Turbox2. After the third time I started to get boost surging like crazy. Tinkered with it most of the camping trip and settled on VGT solenoid.
R^2 Vgt solenoid and clean EBP sensor, everything is back to good. Two days later I hop in to go to work, struggle to build boost, roll coal baby! Lol. Pull over, work the Vgt a bit and good to go
fast forward to last weekend, I hear a noticeable boost leak at 25+ lbs of boost. Leave a stop sign pop cold side charge pipe. Put it back on and drive like a grandma the rest of the day.
Conclusion:
Monday I ordered new charge pipes (sinister diesel), boots, clamps, intake elbow and inter cooler(CSF). Hopefully this weekend I can pull the turbo to clean the VGTs assuming they’re caked from the boots blowing, and install these new components.
Am I on the right track here with my trouble shooting?
Should I be worried about something else causing the boots to blow?
Is stock exhaust my next bottleneck for low spool times? Can I just dummy my cat and muffler or do I need to go 4” turbo back?
or am I looking in the wrong area completely?
I don’t suspect HPOP as I’m not having injector issues.
Sorry if this is crazy, I’m typing it on my phone. I’ll try to edit if needed on my computer later. Thank you in advance for your time.
The good:
The troubles:
Conclusion:
