my bets on the fuel bowl drain valve.
Most of us have been thru this before,It's either o rings,hoses,or fuel pump.Sounds to me with engine running and system under pressure the pump is leaking ,unfortunately for me I too am having pump leaking but not as severe as yours.The valley becomes saturated with fuel and then drains down back of engine.There is a pressure switch on th FPR that will leak,but you can see easy enough.If you have a asphalt driveway,the diesel will eat it up,I know from my last PSD.
x2my bets on the fuel bowl drain valve.
If the ball valve itself isnt the problem you can just get the orings and reuse the valve. I took mine off went to the parts house and couldnt find any orings so I just put the old ones back on and it hasnt leaked a drop since:thumb:thanks for the tip, I'll try to check out the drain valve again.
Do you have any tips/suggestions on the replacing the valve? I don't know for sure if it is plastic or not, but wonder if it will be problematic to try to swap it out in cold winter temps.
The first post above is good advice or info as to what to expect. I would however suggest just buying all new hose, Orings and fuel pump and possibly sensor too. It is too much work to get in there and not it all done.Does anybody have a step by step for pulling the fuel pump out or of at least how to get in there and tighten down all the connections? I am having pretty much the same issue. Fuel collecting in the valley on both sides of the fuel filter housing and dripping down the back of the engine over the transmission cover, bell housing, and starter motor.
pretty much what i just saidfor the last two weeks i've been diagnosing a fuel leak in my valley, and found put it was leaking from 3 different spots
1. right fuel hose under turbo had small hole
2. fuel filter sensor under the fuel bowl
3. left fuel hose under dp bolt to motor
and over those weeks i had the fuel bowl out about a dozen times
what help me alot was to remove the fuel bowl, and clean it with brake cleaner, make sure its spotless, and clean up the engine valley by soaking up the fuel with a bunch of paper towels or rags, just make sure its dry, then reinstall it, fire it up and let it idle for a while and try to see where its leaking from (front/middle/rear of valley) and drive it for about 10-15 miles, then strip it down again and see what has diesel fuel on it, this is how i found out my sensor was leaking, its a time consuming process, but it will definitely pin point where you are leakin from i'll post some pics up sometime this week to help illustrate
