So I decided to test my voltage this weekend cause my ficm voltage on my cts fluctuates quite a bit with the lowest value I have seen was 44.0 volts.
I tested the voltage on the screw as said in the testing procedure and it was at 48.2 at idle and 47.7 at 1800-2000 rpms but the cts display would drop down to 46 volts.
Now I have a 4 pin ficm is that screw the only spot to test the voltage at? Where does the computer get its reading from? I didn't do the test completely cold because I was mainly worried about what it was showing while driving.
Sent from my DROIDX using AutoGuide App
