1 - 19 of 19 Posts
· Registered
Since it started getting cold, around 20*, when I start my truck in the morning, it idles rough and FICM reads about 43-44v according to my insight. Is this normal or does it sound like it's on it's way out. Also, I just took a trip to upstate NY, while driving up there 15-20* outside air temp, my EOT/ECT delta was as high as 17*, once I got back to NC in the warm, it was back to 4-5* delta.
Any feedback is greatly appreciated. Thanks.
Truck now has 167k miles.
· Registered
I would get it rebuilt, they say less than 45V at any time = rebuild time. Send it to FICMRepair.com, Ed will take care of you!
· Registered
Problem is I can't be without my truck, only vehicle at the moment
· Registered
If you check out the website, it looks like they might have an exchange program where you can order one (probably paying a core charge) and when it gets to you you install it and send your old one to them.. I don't know, I sent mine to them and it took about a week (including shipping, I didn't do the overnight thing).
· Suck, Squish, Bang, Blow!
Not normal. Your FICM is toast. It shouldn't drop below 48 volts anytime.
· Registered
Thanks, I'll check out the site, but doesn't it have to be programmed for specific trucks or am I thinking of something else?
· Registered
Discussion Starter · #8 ·
Replaced the FICM over the weekend, plugged it in started right up. It wont get more than 47.5V according to my edge . I should've checked before, but i decided to check for codes and came up with p0611. would the code stay there if I put a good FICM in? or would this reman one cause it?
· Registered
What about the input voltage? I've noticed that after the glow plugs have cycled my voltage is down to 10.5 - 11, truck starts fine and FICM voltage is always above 48 v. I've been thinking about new batts but hate to throw $300 at it. I load tested both batteries and they passed. Coach
· Registered
Discussion Starter · #11 ·
I didn't load test them, but with a volt meter KOEO, 12.3V both, thats with the hood light on..... I just gotta get the patience to take em out and get em tested, even with the previous FICM, after it warmed up it would stay at 48V
· Premium Member
The power supply side of the FICM merely takes the available input voltage (BATTV) and multiplies it by a factor of 4. When I go to start my truck (cranking and glow plugs on) my BATTV is 11.7 to 11.9 depending upon ambient engine temperature. This produces an FICM_M of 46.8V to 47.6V. As soon as the engine starts the BATTV increases to 12.6 to 12.8 while the glow plugs remain on. This keeps the FICM_M at 47.5 to 48.5 (~48 being the maximum output of a stock FICM). Once the glow plugs cycle off (about 60 to 90 secs) then BATTV jumps to 13.8 to 14.2. FICM_M stays between 47.5 and 48.5.
Until my FICM half shell was replaced recently, my FICM_M would be as low as 27 to 28 just after startup, and would gradually rise with increase in ECT/EOT, until ECT/EOT reached 145F, when FICM_M would jump to 45 to 48.5.
Hope this helps.
· Registered
Discussion Starter · #13 ·
my battery with the truck running gradually climbs to 13.3-13.4 fairly quickly. So I guess running around 47-47.5V is alright
· Premium Member
The only way this make sense to me is if the ECT was low when in the 15*-20* weather. Your ECT should be at a minimum 190*-192*. If it is running in the 180's or lower your thermostat should be replaced.
What were the values for the ECT/EOT when you saw the 17* delta?
· Registered
Discussion Starter · #16 ·
I run 160 to 175
· Registered
Discussion Starter · #18 ·
I have done plenty of T-Stat changes in 5.0l, is it a simple job in these as well?
· Registered
I just did mine in the driveway, about 0* outside. I pulled the air filter assy it gave me a lot more room, took maybe 45 minutes but that included the time I fought it before I took out the air filter, lost about 1 1/2 gallons of coolant. Good luck. Coach
1 - 19 of 19 Posts
