1 - 13 of 13 Posts
Street Scene Grille Insert and Fender Badge Inserts
Fender Badge: Fit Perfect!
Grille: I have a painted surround coming on Monday.
You'll also notice that my front Mag Hytec cover is not there. I had a small rubbing issue between my trac bar and the cover so I took it off and tried grinding 1/8" off of it. The cover still was dangerously close so I had to remove it. I am going to go with Rize dual stablizers up front so the cover won't work for that either. I'll make somone a good deal on the cover if they are intersted. PM Me.
Removed factory rear dinky sway bar: Cleaned up the rear a lot I think.
Very good looking truck
looks good. any disadvantage to taking off the rear sway bar? Bump... Some nice traction bars would really set it off.
a truck
That is one badass lookin truck, some harley headlights would look awesome on your rig
The sway bar serves more of a purpose when you have alot of tongue or bed weight. I pull quite a bit so left mine on...figured it has to serve some purpose when pulling. If I didn't pull much or at all I'd yank it I think.
Also, great looking truck man! It's a bit different than the norm and I like that.
1 - 13 of 13 Posts
