1 - 20 of 24 Posts
Ok guys so my FBD 5" exhaust comes out like 3" from my back tire :doh: , what should i do when i get a lift and bigger tires!? :dunno:
either 35" or 37" tires......
other than that this exhaust is GREAT!
Discussion Starter · #2 ·
:bump: :bump:
ya it would, i had a bully dog 5in before an it did the same thing. i lifted it an it was far enough away from the tire that i didnt worry about it
I mean horizontally. looking at the truck from the side, the exhaust comes out right after the tire, the distace between the exhaust tip and the tire (tread of the tire) and the side of the exhaust tip is less the 3 inches......
Did you end up haing to bend anything??
I might send farmboy a message and see if he can help me out.
ya thats how mine was tight aginst the bottom of the bed an was like 3in away from rear tire.
no i cut the pipe up under the truck an mad an offset my self an then welded it back up
Discussion Starter · #9 ·
dang ok. Im worried about it hitting. would it be possible to bend the pipe?
take a picture for us
if you or someone has accsess to a bender, possobly. but it would be easier to cut an weld it. thats not the first fbd exaust i no of that hasnt fit properly
Discussion Starter · #12 ·
Didnt think of that. could you take a picture of the pipe and how you did it?
Thanks haha
Discussion Starter · #13 ·
Thanks haha
i can try to get it, i sold the exaust a while back but i no the new owner so ill se what i can do. are you going to speedworld next weekend?
Discussion Starter · #15 ·
Dont think so. I have to do the treatment for my thyroid on thursday, I have to take iodine 131 and it kills my thyroid. Problem is, its radioactive and i have to be pretty much in quarentien (sp?) for 4 days.....right as school gets out too! so im pretty bummed....
Im gonna be on the org ALOT hahaha.
dang that sucks. i was going to say if you were going to be there i could show you how i did mine. it really easy tho
Discussion Starter · #17 ·
yea, i wish i could go. Im pretty sure we could figure it out. Ive gotten to know the diegrinder very well since i got the truck!
What kinda welder did you use? We've got a MIG welder at the cabin we can bring down.
Discussion Starter · #19 ·
ok. sounds good. i needa weld everything together anyway...its all clamps that came with it now.
clamps will work fine. i would just put a couple tack weld on the connections just incase you ever need to remove it someday
1 - 20 of 24 Posts
