1 - 20 of 25 Posts
:help1: I think I have an injector going.... :sad:
Here are my symptoms: Just a little sluggish to start, slightly higher fuel consumption, and when driving down the road and you hit a hill when It downshifts you can ALMOST feel what seems to be a miss.
I talked to a friend of the family (He is a diesel mechanic) He said to run a lil cleaner through it as it sounds like it may just be sticking a lil or have carbon build up. I will try this today.
What are the signs of a failing injector?
Next question, IF i do end up having a failed injector or injectors I will be doing the work myself. Should I go a head and replace ALL injectors with a set of Stage 1s (155s) Or just replace the bad ones? :dunno: I should be closing on the sale of my house on Sept 30, so I will have a few extra dollars.... HELP!
Well mine was doing what you're saying and mine would also have a rough start and would have no power until the truck warmed up. Its at the dealer right now and they called today and said they we're replacing the fuel pump and if that dosent fix it they're changing the injectors. I should be getting it back tomorrow so I'll let you know how it goes.
I just had 2 injectors replaced and it was doing the same thing you described.
Discussion Starter #4 (Edited)
Oh jeez.... I was afraid of that. It also has NO power until warm, I went out and started it and let it idle for a second and then tried to move it a few spaces closer to the door and it just felt like crap and sounded like a gasser with a BAD miss.
Also, added some fuel additive and after about 15 miles, some of the roughness in driving went away. Is there any know way to check my Fuel pump? I know a fuel pressure gauge, but where do you hook that up???
Also, as asked before, what would you guys do, replace just the faulty ones at about 149 a piece. (plus cost of having it to Ford to find out which injectors are gone) Or just drop 1500 on a whole set of 8 Stage 1s???
I'll ask the mechanic when I pick my truck up how to test out the pump and I'll let you know. But I hope this isnt the prob for you, as Ive heard these pumps can be very expensive.
Injectors are about 200 a piece, so I HOPE the fuel pump isn;t expensive compared to that.... :eek:hnoes:
I am having similar problem, just had egr cooler, oil cooler, and ICP sensor changed, under warranty. But still have an inconsistant miss under load.
I run the best fuel I can find, changed fuel stations, but still get the miss.
It happens usually under load, just before a downshift. If more accelerator is applied, and downshift occurs, it goes away.
How many miles do you have on the truck? Assuming that it is an 05 iam gonna go with like 80K its more theny likely your injectors all it takes is one injector to fail and these signs will happen
Rough start ups
Run rough to warm up
lack of power
Miss firing
if you are having one of those more then likely its an injector. The only way you can test those is a buzz test buts sometimes there still good enough to past that. True and see if your buddy whos a diesel tech get a scanner and scan your truck even if the CEL isnt on codes will still appear. I just did an 05 with 160k same problems as you cylinder 4 injector was bad replace it along with a set of fuel filter customer said it ran unbelievable had power from the cold start....These high pressure oil injectors have a 2 stages to them 1 being a cold stage ( which is very common to fail on these injector) Stage 2 is a warm stage. Ford will probably charge you 100-150 bucks to tell you whats wrong depending on your dealer. If you get the injectors from ford they run $283 with a $180 core charge. So i would pull your old injectors out first then go get knew ones to save some money if though you get it back but still. Heres some hopfully info chart if you do your injectors yourself these are the cylinders and how they are numbered
Drive side (L) Front Passenger Side (R)
2 1
4 3
6 5
8 7
Lets start simple here. You said the problem went away when you put some additive in.
When was the last time you changed fuel filters? Also is this only happening when cold? If so do you have the latest reflash?
How many miles on the truck? If you are under 100k take it in.
If not get it on a scanner that can datastream and run contribution and buzz tests those will tell you if you do in fact have a dead or dying injector.
Fuel pump runs about 600 bucks from ford if you are out of warranty.
If you are out of warranty and the pump is bad get an airdog
Good point dave i just think of the worst that can happen .... I really gotta stop doing that
:thumb::thumb:
Discussion Starter #12
The filters have about 8k on them. I was going to change them with the next oil change in a about 2K but will probably go ahead and do that now. It was REALLY bad when cold but it was still noticeable after it was up to temp
The truck just rolled 77k today, I am going to try and take it in. (see below)
So, you recommend an airdog over FASS or Raptor?
(Replies in red duh)
Thanks Dave. I knew you would have some good info (not that the others didn't!)
As far as the warranty, I am scared of that. Warranty is the reason I now have the PSD. Long LONG story short, Had an 07 Jeep Wrangler, starting having an oil consumption issue, (broken ring) took it in, 2 MONTHS later, denied me on warranty... Apperantly taking a Jeep off of a paved highway Voids the warranty :tard:
I am scared they will get the truck in there, find something to eek out of a warranty fix and then I'm stiffed with a bill for what has been done thus far, taking $$ from my "repair budget" I'm just torn about that and SOO leary of warranties anymore. Main concern: Truck had a smoke switch :doh: Has since been removed and patched back in a way that LOOKS factory, but if they look hard it will be seen...
I just don;t know what to do.......
Discussion Starter #13
Okay, went out and started the truck, let the glow plugs heat, cranked it for about 3 seconds and she fired right up. But it was idling rough and I could hear almost a 'miss' in it. As I said, I will be closing on the sale of my house soon. I think I am just going to let it go until the end of Sept (baby it and not drive it as much) and then do a set od Stage 1s and an Airdog 100 setup. I love my Powerstroke, but boy when something goes down in them, it really hits hard.... Oh well. I still love it! :thumb: Thanks for your help guys!!
Get it in Erik and let the warranty take care of it.
Fords warranty on these trucks are better than anyone elses warranty that I've seen, they really take care of you. Mine was doing exactly what you're saying yours does, I should get it back today so I'll let you know what the problem was.
Well I just got the call and it looks like its the injectors, Im not getting it back till tom. Oh well, I got a brand new fuel pump out of the deal! I hope they're right this time.
Yeah bud i would say get it in also and let them take care of it pushing it can just make things worse
Discussion Starter #18
It's going in guys. Thank you ALL for the help and advice! :thumb:
sweet let us no what happens
1 - 20 of 25 Posts
