I think mine (155k) might be acting up. Prod date on my truck is 04/03.
What I need to know is what year engines can I pull a used FICM off of that will plug and play. Is it 03 only? Or 03 and early 04? Or do I really need to match them up?
Any help here is appreciated. I just want to swap one first and make sure that is my issue before I spend the $$$$$ for an upgraded one.
The issue is NO POWER during a "cold" start. Could be 90 degrees out, but truck hasnt been driven in over 24 hours. Once warmed up (ECT/EOT up to temp) the truck builds boost and runs like a raped ape. But not for the first 5-8 miles. Esp the first 2-3 miles.
Thanks all! :icon_ford:
Any FICM from any year will work. The only thing you might get is a code for PCM not being matched with the FICM, but it won't turn on the CEL.
Ok....thought I had read somewhere that the plugs were different on some years, just couldn't remember what years.
