1 - 5 of 5 Posts
I have a 2004 Ford F-350 and it sits about level now with the leveling kit I have, the problem is when I tow it’s usually a pretty good amount so I want to avoid it doing the Carolina squat. So with my truck being a single rear wheel could I get a F450 leaf setup onto my truck or would it just be best to do a block kit or an add a leaf?
I think the F450 springs for your year (by your picture) are too wide. Not to mention the unloaded ride quality. If you locate a set for Dual Rear Wheel (DRW) F350 springs you might have better results.
Air bag it. Keep your current comfort and ride height, air up to level it when necessary.
BTL
Mr. Crossthread
I agree with @BTL on the airbags. They are pretty simple to install and work great, the newer air lift kits are superb. Out of the dozens I've installed I haven't had a single complaint, only 1 valve failure but the truck was a hotshot hauler and had the system for 200k miles.
Bag it!
Seriously, I have a 14 dually and getting ready to go LESS on springs. I've been to a couple salvage yards and found a set I will likely buy this week. The ride is horrible empty and I don't pull a 5th wheel so I don't have high pin weight. I pull a tag car hauler so I like the stability of the dually but don't need the heavy capacity. I'm going with 250 springs and bags.
Tom
1 - 5 of 5 Posts
