Sooo I'm buying an f350 and the one I've seen has some issues:
Heavy rust under the body - on differential cap, exhaust, u-bolts, etc
Rear driver side door hangs and rubs
Noticed the AC pipes sweating?
Also squeaking coming out of the front end drivers use on left hand turns
It's a 2006 crew cab 36k miles what do you guys think? Buy or don't buy?
I have a 2008 f150 fx4 now but I don't want to plow with it
With 36k miles I'd be a bit suspicious. I know it might seem like a great find but these trucks NEED to be driven often and worked hard to stay healthy. Also low miles might mean it spent alot of time in the shop. Either way I'd be suspicious.
As for everything else it honestly sounds like the truck was neglected. What is the asking price?
Are the EOT and ECT in check?
The truck inside is very well kept and under the hood is spotless..selling for $22000 with the v10 6.8 gas
Noticed it was registered commercially it was either used for plowing or pulling boats
The other truck I'm debating between is a 2010 f350 v8 5.4L gas...29k miles $30,000...no rust but $8000 more
