1 - 12 of 12 Posts
i have a 2004 f250 6.0 that turns but wont start. i have replaced the camshaft position sensor and still nothing. it has 52000 miles on it and the dealer said its not under warranty since its over 5 yrs. i have suel going to the top fuel filter. can it be the ficm or the injectors. i dont want to spend an arm and leg at the dealer.
Sounds like we are in similar situations ( http://www.powerstroke.org/forum/6-0-motor-problems/105409-6-0l-cranks-but-wont-start.html ).
First of all, you gotta get a code reader - you didnt mention one, so Im guessing you havent tried that.
IPR/ ICP were two things I ran down previously, but ended up eating it at a dealer since I was out of town.
FICM is likely, but a code reader should let you know.
52K miles seems a little early to be having problems with the injectors.
Im about to change the oil, since Ive heard the injectors can get gummed up with dirty oil. Its a sunday, so its not like I can get any other parts anyway.
no faults....does the oil pressure build as you crank?
is there sufficient oil in engine?
you didnt put gas in there did ya?
FICM if dead- you wont hear the injector buzz when you key on engine off.
wont start
on the gauge the oil pressure doesnt move.the oil level is good. i didnt put gas in it. i hear a buzzing news for a few seconds then nothing
What are you using to pull codes
wont start
im using a ob II reader.one from advance auto. i know it doesnt go in depth but if something is wrong shouldnt it be able to pull a code
Those will not pull codes on a diesel. Need to get it on a scanner
and a super important one...how is the battery voltage?
you can have all things go well, but have <10v (IIRC, might be slightly higher) and it wont start
Are you sure your pressure gauge doesnt move even after you crank it for a few seconds?
I, 1, 2, 1/2, 6
my OBD II scanner I bought at AutoZone reads codes on my truck :dunno: When I had the MP-8 and the ICP plug was messin' up, it set my check engine light. I scanned it, it read the code
An autozone scanner is worthless if you want to make an accurate diagnosis.
1 - 12 of 12 Posts
