1 - 15 of 15 Posts
The exhaust tone of my truck at idle changes from the turbo whistle to more of a rumble then goes back to the whistle. It will do this if i let it idle for more than a, minute is thus normal?
Sent from my DROID RAZR using AutoGuide.Com Free App
WWW.COMPIGNTECH.COM
Thats the vanes in your VGT cycling. My buddies truck does the same thing and I think it sounds bad a$$ but mine won't do it, I don't know for sure why but I have read somewhere that when the egr is deleted (full delete, valve and all) and you restart the truck it doesn't get to relearn the idle vgt cycle or something to that effect. I wish mine did do it cause it would really piss my neighbors off lol. So anyone know how to get mine to do it again???
That makes sense it didn't do it until i just did my delete. Do I need to do a turbo relearn?
I have full EGR delete and just installed a few weeks ago 4" MBRP no muffler/ kitty. Mine does same thing. Interesting to hear why. I was wondering same thing as OP , but I think it sounds bad a$$ as well
It's part of the VXCF9 strategy. My truck did it until I tuned it. Since the tune is based off of the VXCF4 it doesn't do it anymore. I might see if Matt can add it back at some point.
Mine does it with egr delete and valve still in place. I'm running SRL but I think it is written to a newer strategy, I'm guessing with the vgt cycle. Haven't checked strategy yet. Sounds intimidating. Would be pretty sick to get a constant idle like that.
Discussion Starter · #8 ·
As long as its not hurting anything i like the sound just didn't know if it was indicating something was wrong. I wish it would always sound like that I like the low growl.
It is normal. My 03 does it - I have the VXAP2** strategy.
mine did the same thing for a while then it was a straight up rumble at idle and acceleration, the exhaust note changed considerably. wound up being my ebp sensor, replaced it and i have the turbo whistle back at both idle and acceleration.
Discussion Starter · #11 ·
Im also throwing a p0069 code map/baro correlation. No cel just the code. Could they be related
totally normal depending on your strategy. mine did it with the egr system in place, and deleted. im running vxan0n0 now. im not sure if this super early strategy does it. i dont ever run it stock, and my tunes keep the veins open at idle
its all about strategy, mine did it stock then i got it tuned and it stopped. i got vivian to add it back in and she did. it sounds sweet
its called vane sweep, if someone hasnt alrready said that
1 - 15 of 15 Posts
