1 - 7 of 7 Posts
I drive an 03 f250 7.3. I was thinking about getting an exhaust, the thing is iI have very low funds, a friend told me that since it already has a 3.5 inch exhaust with no cat from factory I could simply delete the muffler. I don't plan on to many mods (have K&N drop in filter and may get a programmer soon)nor do I drive very aggresively. I don't care if it's a bit louder, just curious if it's worth it or if anybody's done it. Maybe an 80 dollar investment, please you opinions.
80 bucks might get you a muff delete pipe... you can get aluminized in 4 or 5 inch for quit a bit cheaper than stainless, but then again, 80 bucks wont get you much... u could easily delete muff w/ straight pipe tho for 80 bucks
Exactly and though I have found exhausts for about 300 I don't have funds. My buddy told me he did it and it worked great for him
If you don't have an abundance of funds, do a search for DIY Tymar intake. That'll fix you up.
I'd say do the muffler delete... I did it for free myself, but that's just cause I had the pipe and welder there... I did the tymar/DIY air filer (about $45) and unpluged the wastegate, and am quite pleased with the truck now... Noticeable diffrence. I did put in gauges, but doubt you'd have to do that to take advantage of the mods I've listed.
Good luck!
Greg
Lubrication Addict
These days, most of us are on a tight budget. There is nothing wrong with 1 mod at a time. Do your air intake first--K&N has a bad rep around most diesel forums. Then the muffler delete-Straight pipe it will give the most improvement. With out replacing the whole system with a 4" turbo back. Then get a good set of guages-->If your next step is a programmer.
Treat your truck with respect, and it will take care of U in the long haul.
1 - 7 of 7 Posts
