1 - 8 of 8 Posts
Desert Shield/Storm Vet
The sensor eliminator just eliminates the code from happening. Won't help you out in any other way then stopping the pcm from storing the code:thumb:
thanks, so how is it that people are claiming 1-3 mpg increase after cleaning the tube and sensor
the tube is full of soot so is the sensor..so it sees nothing , and adjusts for the worse.
be carefulle when handling the tube ..mine was old and brittle.
guzzle's page has a good cleaning directions.
so by putting the fooler on there, theoreticaly you should see a increase then, so its not adjusting for the worse
in theory possibly? or it could make it terrible,
all depends on what the fooler shows..if it has a fixed resisitor to feed the magic number..yes. if it is just a plug no , it could do more harm then good.
I know of a few guys that use ebp foolers-one of them liked them, 2 still have codes.
no sure whose sensors they used.
The PCM uses the EBP sensor for several tuneing paramiters... clean it and leave it be...
thanks for the help... it looks like when i go to remove the tube from the manifold something is going to break due to the rust... if the fitting on the tube breaks i can get a new tube but if the fitting on the manifold breaks im screwed probably.
1 - 8 of 8 Posts
