1 - 5 of 5 Posts
· Registered
I was wondering if the front seats from a Lariet Excursion will bolt up and plug into a Lariet F250. The biggest difference I saw was the Excursion had heated seats and I didn't know if there was a plug in the truck for that. Any help would be greatly appreciated.
· Registered
From my understanding, the plug should be the same.
What is your plug like now? Round with 2 prongs on the inside?
You should be able to reach under the seats from the back and pull the plug off the clip and the plug's joint (where the 2 ends plug into eachother) will reach to the back of the seat. You can unplug it quite easily then.
· Registered
· Registered
Know what? If the plug is the same? Look.
The seats will bolt right in. If you dont have the power there for the seat heater then add it...
Good lord.
1 - 5 of 5 Posts
