E04 Ford X EB 6.0 SixGun w/ M Exhaust, Clown, Monster Exhaust, BPD FICM & 7.3 Fanmod, CAI, 4X4
E04 X. 250k. Stock turbo (new VGT solenoid), updated turbo oil supply & drain, OEM injectors (2k miles), BPD water pump, SD EGR delete, 7.3 bpd fan mod, cold air intake, FS by pass oil filtration, SD coolant filtration, Banks 6 Gun w Dash IQ and monster exhaust.
short story: wife’s ride until we had our ninth kid...she’s hot. Married way out of my league. At nine, she got a transit. I finally got the X. PTL!!! A week later, hpop. Then injectors. Why? Crap mechanic. She may have birthed 9, but I have been ridden hard and hung up wet by every dealer/diesel shop in this burg. But last year I thought I found a good one.
new mechanic honeymoon was great. Finally fixed my hpop leak. Then my upper oil pan leak (after I had already paid someone else to do it). Then I had them do all my injectors back in April of 19. It was a daily driver and I pretty much ran an Econ tune forever.
I was towing a trailer in April 2020 and was T boned but the impact was my trailer.Wound up jumping the X over a drive way towing 6 yards of wet mulch about 3’ of air. Still ran but no steering or 4x4.
Took it to my shop. Insurance got the bill, so I’m like, “fix dis!” New oil lines, furl lines, hub assemblies, Warn hubs, cold air, stabilizer, shocks and turbo up pipe. I only gave one request: check the head gaskets.
8 freaking weeks later (insurance not mechanics fault) I get a call. “Almost done man. Just one question: did you ever have overheating issues?
Heart stops. “No. Never. I know my Deltas like I know the Gospel.” (I baby this think)
next day phone call. “Hey, can you come down here? Need to talk.”
the talk. “Your head gaskets are blown. Mike didn’t check and now it’s all together and he just quit. So, now I don’t have a diesel guy and we can’t fix your truck.” Still got paid $3800...
So, I am done fooling around. This is the last time! (Right...) I’ll fix it my dang self.
Disclaimer: I’m in sales. I have two project cars and they are power wheels. And they don’t work. Seriously. I’m not technically gifted at all.
So, I join this forum and read everything I can. Here is what I decided to do:
ARP studs, New CAM position sensor drivers side, head gaskets, heads machined while maintaining etching (I know I’m brutalizing this), new icp, IPM, ebp sensor, banjo bolt upgrade, 7.3 fan mod, bpd water pump, turbo supply and drain tubes updated, vgt solenoid, turbo serviced polished and cleaned, new glow plug harness, new injector harness, bpd FICM, new thermostat, EGR delete (had it just never did it), and some custom engine bay paint. Why paint? Because I needed to fill the time while waiting for my balls to drop to go to the next level.
So, build complete. Going for the test start and idle test. Follow the cycling procedure and the first true attempt to start, she starts with a roar!!! The 7.3 fan mod scarred the crap out of me. I thought I blew a pipe.
She idles smooth. No smoke. I was expecting a lot of smoke. None. I kept the build surgically clean. Still, no smoke though.
I know how it used to sound but with all those changes, I didn’t know what it was supposed to sound like...but that sound made my man parts tingle.
That’s where the fun ends. I soon notice my idash is not getting data. I’m getting voltage, no data. Easy, blown in line fuse (never asked myself why). Replace fuse and there we are. Take it for a short test drive and...it runs like a moose on ice with three broken legs. Awful. Then, no data from idash. Fuse good. Nothing coming in. Grab the scan tool and I have 19 freaking codes! Some of these codes are unreported or hard as heck to resolve and I need help in a bad way. Obviously, based on my mods, I should have four background codes; fan and EGR. But the rest, please help?
1408
0403
0405
050C
P0C14 drive motor B inverter phase U over temp invalid signal
P0000
460
1876 transfer case 2wd drive solenoid circuit open or short to ground
1832
1483
B1352 ignition circuit
U1262 CSP data fail
P0046-60 turbo boost control solenoid circuit range/performance
P0281-60 cylinder 7 contribution
P0480 cooling fan
P0528 cooling fan
P0671 cylinder 1
672 cylinder 2
673 cylinder 3
674 cylinder 4
675 cylinder 5
676
677
678
After my test tonight, this is what I have. I put four hours in to checking every wire I could. No breaks or burns. It looks good.The poc14 code threw me. U1262, can’t find it. The P046 is why I changed the vgt solenoid.
I have been asked if I put the belt on correctly or if I could have a big air pocket. Belt I believe, is on correctly. Air pocket? I have no clue.
I desperately need guidance. Any help would be appreciated.
1408
0403
0405
050C
P0000
460
1832
1483
U1262 CSP data fail
P0480 cooling fan
P0528 cooling fan
P0671 cylinder 1
672 cylinder 2
673 cylinder 3
674 cylinder 4
675 cylinder 5
676
677
678
