You don't need any fuel pressure spring mod. That is a 6.0 thing. Monitor your fuel pressure to see what you actually have. Idea pressure for a 7.3 is between 55-65. Anything more is harder on the pump, and can cause the fuel bowl to crack.
Oversized banjo bolts are an absolute waste money. We have many customer trucks into the 700+HP range with factory banjo bolts. Best kit for your needs is our bowl retain fuel kit. You'll have to replace your fuel lines eventually anyway as the factory hold downs will rub a hole in them.
CNC Fabrication 7.3L 4 line feed fuel line kit
Upgrade your fuel-system with our 4-line-feed fuel-line kit designed to eliminate the infamous #8 injector knock and fuel starvation in the #1 and #8 cylinders during higher RPMs and heavy throttle while towing.
KC stock plus turbo is a new turbo with their balanced assembly installed. Benefit is it's under warranty, and if you're not comfortable rebuilding your stock turbo. Perfect charger for stock injectors. The 63/68 will be slightly laggy compared to the stock plus on stock injectors due to the wheels being bigger.
99.5-03 7.3L KC Turbo Stock Plus Turbo - 300132
KC TURBOS 99.5-03 GTP38 STOCK REPLACEMENT TURBO - KCT-GTP38 This turbocharger is a great replacement for your worn out stock turbo for those wanting to stay with stock injectors up to 160/30's in their 1999.5-03 Ford 7.3L Powerstroke. For larger than stock injectors, we do recommend the KC38R...
Be careful on which 6637 you buy. They are NOT all the same, and are not cleanable like the AFE version, so in the long run, you'll end up paying more money for filters.
AFE POWER MAGNUM FLOW PRO DRY S AIR FILTER - 21-90058
AFE POWER MAGNUM FLOW PRO DRY S AIR FILTER 21-90058 PRO DRY S OIL-FREE MEDIA FOR MAXIMUM CONVENIENCE, AND IS A DIRECT REPLACEMENT FOR THE DONALDSON ECB085011 PAPER FILTER (AKA 6637). DETAILS: 19% INCREASE IN FLOW (427 CFM AT 1.50
With just a Hydra, you will be in the 325hp range like a stock 6.0L is. Brian does all the custom tuning for our customers, but you don't "need" his tuning to reach your HP. The Hydra comes with tuning for your truck if you want to save some money.
JELIBUILT Custom Tuning W/ Hydra For Stock or Modified Injectors - 7.3-HYDRA-CAL
6 custom tunes by JeliBuilt Performance with the PHP Hydra Chip. Our custom tuning is written for your particular modifications, such as, turbocharger, high pressure oil pump, transmission, axle gear and tire size, etc. 7.3L Custom Calibrations - Modified Injectors This package includes 6...
When you decide on the larger injectors next year, you'll have to buy another set of tunes, so that's something to think about.
PHP-HYDRA
FREE STOCK TUNES: Your Hydra Chip comes with access to the Power Hungry Performance server by downloading the Hydraflash App at no additional cost to download your tunes. Examples of the stock tunes that already come with the Hydra Chip are listed in the table at the bottom of this page. Note**...
As for injectors, 160/30 are very popular and will get you around 400-450hp. If you decide on these injectors next year, then go with the 63/73 .84AR housing.
99.5-03 7.3L KC Turbo KC300X Stage 2 63/73 Turbo - 300223
This is a factory drop-in journal bearing turbocharger with a Borg Warner 300sxe Style 73mm turbine wheel with a 63mm billet compressor wheel for the Superduty late'99-03 model years. This turbo will impress you at how well it runs! KC Turbo has torture tested it for longevity and proven its...
