Are your gauges still usable??? Cause I wanna still wanna use my gauges and still be able to check engine codes and what not. Did you install it?I have a similar setup and I just have my evolution UN-installed so to speak (0 in upper right hand corner) and use my chip as normal.
See above red. Works exactly the same as when you have the tune installed, just with a 0 in the upper right hand corner.Are your gauges still usable??? YesCause I wanna still wanna use my gauges and still be able to check engine codes and what not. Did you install it?Yes
No the Evo plugs into the OBD2 port...which connects to the ECM but it is not hard wired. The Evo is a programmer which re-flashes the ECM. The chip will override the flash of the evo. Leave it on 0 and you will be fine.Ok, well I was confused with the 0 thing until I drove my truck this morning and saw the 0. So the ts chip goes into the pcm as to where the evolution is like hard wired into the truck right? Sorry if sounding dumb, I'm new to the diesel thing
Yeah that ain't even close.Ok, cause I was wondering how I'd hook 2 chips into the same place but that's not the case..... And I live in medford Oregon
Probably about the farthest place away HAHAHA but thanks for all your help!Yeah that ain't even close.
