Ok so I thought I'd get this thread started a little early to get some input from people more knowledgeable in the diesel world.
Objective:
Convert a 6.0l Powerstroke over to waterless coolant. Increase coolant operating temperature and fan on set point.
Known solutions/issues:
Several people are already running Evans with no issues.
Fan on set point can be modified in your custom tune to make use of your high temp coolant.
High temp thermostat is not available to my knowledge.
Proposed solution:
I was thinking of modifying a stock thermostat to incorporate a low profile linear solenoid. The problem with this however is where do we get the trigger from. I was thinking if we wire it into the fan circuit with a resistor/capacitor pair on the lead to the fan. This would be used to delay it by a set period. As a result a thermostat with an adjustable set point would be created.
Feel free to weigh in. I'm still trying to organize my thoughts on this one and have definitely not considered all possibilities / ramifications.
Greg
Objective:
Proposed solution:
Greg
