1 - 2 of 2 Posts
installed my fuel pressure gauge tonight and the needle bounces back and forth between like 80 and 100 Psi, its never at a constant pressure. I have the pressure sending unit mounted to the upper driver side of the fuel bowl. Any ideas?:dunno:
if that gauge is accurate, the pressure is set way too high. it should be set down to about 55 to 68 psi. that high of pressure will kill the pump!
1 - 2 of 2 Posts
