Hi Everyone,
New here. I have a 2005 F250, 299k miles, previous owner did the following: EGR deleted, head studs, there is no CEL and EGT valve always reads 0% for command and status so there may be some sort of tune in it.
The truck drives like it is stock from what I can tell. I don't tow anything ever.
All of the values/temperatures I list in this post are as read from my OBDII scanner.
So I read this thread on recommended temperatures and pressures (sorry about the other forum): Recommended readings - Temperature and Pressure - Ford Truck Enthusiasts Forums and now I have some concerns about my engine oil temperature.
When driving down the highway, flat road, after 15 minutes, cruise set on 65 MPH, my EOT is 232 and my EC is 195. So my questions:
Other possibly relevant details:
The truck seems to be running fine. The only trouble is that when it cold outside (under 32°F) it it very hard to start. When I plug in the block heater it starts with no problems.
Thanks everyone,
Andy
- Is this temperature normal considering the EGR cooler is deleted?
- If this is not normal (which I expect that is the case), how BAD is this?
- Is this go trade it in on a new truck right now bad?
- Or is it more like stop driving the truck immediately and replace the oil cooler tomorrow?
- Or is it yea, it's okay to run to the parts store or whatever, just replace that cooler in the next month or so and drive it easy.
Thanks everyone,
Andy
