1 - 18 of 18 Posts
Vendor
Element Fire Extinguishers - Now available at XDP!
The Element 40050 E50 Portable Fire Extinguisher is a game changer in fighting all major classes of small to medium size fires (Class A, B, C and K). This fire extinguisher was developed for the space program and battles fire by interrupting the chain of combustion on the molecular level without removing oxygen or making a mess. Lasting 5x longer than a traditional fire extinguisher and about 80% smaller means it takes up less room while being more efficient than typical extinguishers.
Easy to Store and Transport:
The compact size of the E50 Element makes it ideal for use in Trucks, Cars, Boats, RV's/Campers, Garages, Trailers, and Classic Cars. Easily store one in the glove box, center console, or a map pocket in your vehicle in case of an emergency. A wide variety of add-on mounting options for custom applications are also available - Magnetic Mount (60500), Seat Rail Mount (60300), Roll Bar Mount (60200), or Carbon Fiber Mount (60400).
Non-Toxic Extinguisher:
While the discharged should not be aimed at anyone’s face, the discharge from this extinguisher safe to breathe and both non-corrosive, and non-toxic for animals and children.
Less Discharge Residue:
There can trace amount of soot from the casing, but it will not leave any residue and even in the most extreme cases would be so much less than a tradition extinguisher that it would be comparatively nonexistent.
Long Service Life:
There are no moving parts or gas under pressure with this extinguisher and the Element’s solid construction means there is no service or maintenance needed to keep it in working order as it is unaffected by extreme heat or humidity provided the yellow cap is never to keep the tip dry. The solid chemical that the extinguisher is comprised of has no effective expiration and has been tested to work in temperatures ranging from -140F to +320F.
Administrator
Interesting, but would I bet my (or another persons) life on it?
No need for burn permits in my area anymore so brush piles are lit all over the place. Maybe someone "cough, cough XDP" could send me one and i'll test it on a car that accidentally crashes into a brush pile lol????
I like the size and very interested for the side by side. I may do some digging.
Administrator
@JustinOOO9 we will only know it works from inside the car.
@Justin0009 we will only know it works from inside the car.
That's ok. I can handle it safely lol. I just wont choose one of the bigger ones :grin:
Vendor
We are trying to convince ownership to let us set a vehicle on fire in the parking lot here, just so we can sample one...:grin:
I suggest the Prius with the feel the Bern bumper sticker
Sent from my SM-G960U using Tapatalk
It is What IT is
Actually ANY prius will do....:grin:
Reactions: voodooridr
It will be a Prius Bonfire! :thumb:
Keep tossing them onto the pile till you can see the flames from space
Reactions: ZMANN and Heavy_GD
Administrator
I was just watching the video from Element again
just like an engineer to stand in the path of the extinguisher discharge and smoke lol
all of us wrench types would be on the fender side breathing fresh air or actually just watching that POS burn from a distance and not wasting our fire extinguisher LOL
Administrator
You would sell more if there was an option to mount your phone to it for a POV video. #doitforthegram
Fire From the Clouds!
Who would have thought a thread about a fire extinguisher would be so lit!
Administrator
1 - 18 of 18 Posts
