After initial start, usually within 5 or 10 minutes of driving, the engine shuts down, tachometer goes to zero, cruise control shuts of... Its as if I've turned the ignition off and back on again. If I've got 1000 rpm or more it shuts off and restarts in less than a second. If I'm idling I have to crank it over to restart it... I'm puzzled... Ideas ???
1997 F350 CC LB Dually Battery terminals tight. CPS ? I'll install new one. No engine check light. I'll check for codes. Thx guys !
The new CPS did it ! Starts faster. Idles smoother. Runs down the highway smoother and a bit quieter. Better throttle response. I'm guessing I may even get a little better fuel milage. 🙂
