1 - 2 of 2 Posts
I added new Led cab lights and turned them on and they worked just fine, then I turned them off and later when I came out to leave the Cab lights wouldn't turn on, neither did my fog lights or the marker lights on my bed. Does anyone know the solution to fix this problem? Thanks!!
I would assume you started with the fuse box?
The interior cab light grounds direct to the body, and the hot leads are easy to short to the body if they're not secured properly.
Start there and if you still can't find it, I'm pretty sure there's a set of electrical diagrams in the tech files area of this site. If you can't find them let me know, I think I have a copy saved on my computer.
Sent from my Pixel 3 XL using Tapatalk
1 - 2 of 2 Posts
