1 - 2 of 2 Posts
Hey guys!
The fuel pump on my OBS 7.3 went and i've been looking for a wallet friendly kit to replace it. today i got the idea to check out summit racing and found these direct bolt in kits:
Pureflow AirDog Raptor Factory Replacement Lift Pumps R2SBF216 - $389.00
Brand: PureFlow AirDog
Manufacturer's Part Number: R2SBF216
Part Type: Fuel Pumps, Diesel
Product Line: Pureflow AirDog Raptor Factory Replacement Lift Pumps
Summit Racing Part Number: PAD-R2SBF216
Fuel: Diesel
Fuel Pump Type: Electric
Fuel Delivery Style: Fuel injected
Wiring Harness Included: Yes
Mounting Hardware Included: Yes
Quantity: Sold individually.
Notes: Rated 100 gph. Supplies fuel to high-pressure pump.
Raptor factory replacement lift pumps from Pureflow AirDog feed your modified Dodge engine the fuel that it needs to satisfy its hunger for power! These direct-swap premium Raptors are gearotor fuel pumps with adjustable pressure regulators and modified bases to fit the factory position for easy tuning and installation--probably in less than 30 minutes. With upgraded 1/2 in. lines, the Raptors deliver 100 gph--that's plenty of performance fuel, plus enough to support your aftermarket programmer! When your stock lift pump fails, choose Raptor factory replacement pumps from Pureflow AirDog.
Pureflow AirDog Raptor Factory Replacement Lift Pumps R2SPBF357 $525.00
Manufacturer's Part Number: R2SPBF357
Summit Racing Part Number: PAD-R2SPBF357
Fuel: Diesel
Notes: Rated 150 gph. Replaces high-pressure pump.
I thought they might be worth sharing so hope this makes someones search a bit easier. Mines a OBS and apparently there not compatible... these are good from 1999-2003's.
What year dodges are those pumps for? are the internal pressure regulators adjustable to 65 psi? I know the raptor 150 I put on my dodge did not seem to be able to go that high as for the VP44 you want a MAX of 20 psi. :dunno:
maybe you would be best to bypass the failed pump and use a SD electric pump. if you find the right parts for the right price I have heard of people making their own E-fuel systems for less than the price of those pumps.
1 - 2 of 2 Posts
