I just bought the h and s egt kit and I know that a lot if guys here use one of the probs off the dpf for the pyro so with that being said I was wondering how you did you do the wiring to monitor it on a mini maxx?
Thanks tyler
Simple. There are 2 pipes that are connected to the egr. The longer egr pipe is the one that you will be removing to install the block off plates . the shorter one that will stay in place has a temp probe in it.
Follow its wiring down below the air intake hosing and it will have a plug.
Unplug this probe and then plug the probe that you are installing in the block off plate to this plug in.
Then your h&s will read your egts on the Pyro 1 parameter.
Sent from my DROID RAZR using AutoGuide.Com Free App
