1 - 19 of 19 Posts
Hey guys i have recently installed a sct x3 with rivercity diesel tunes which by the way are amazing. I was just wondering wat kind of egts you where getting on your street tunes i can gas on her for just a second and be hitting 1400 degrees wats up with that? Mods to my truck are Zoodad, Afe drop in filter stock exhaust no cat goin to 5 inch stacks love the power but not the heat any thoughts??? thanks in advance..
Smoke Eater
wow i run the extreme race from innovative... and hammering on it for long periods only gets me into the 1300s(although i never let it get that hi)... and normal runnin is 7-800
That seems REALLY high. You may call River City and see if they can check your tune
I called river city and they said they would look into it for me. I was also wondering how much smoke you guys put out on extreme street?? :dunno:
What do you guys run stock. If you remember Id like to no because I can hit 1100 no problem stock and worried about when I get my SCT from cale.
Well i got ahold of RCD and man did they get er rite i am lovin it no my truck is a diff animal
a known holder of grudges
1400 degrees?!?!? I was always under the impression that 1200 was the death mark. I've seen the heads on a few PSD that had thos numbers, and it don't look good. 1200 makes me nervous, 1400 would have me in a panic.... I could be wrong, but what I've seen on those heads ....:eek:hnoes: :eek:hnoes: :eek:hnoes: :eek:hnoes:
I run innovative extreme race and I can hit 1400 in a few seconds with WOT. I always thought that was pretty normal, although I very very rarely go full throttle.
time for meth
Bring On The Snow
I run extreme street from innovative and was at the track the other night and i hit 1600 every time.
There is no way that's good on the valves,......that's seriously hot and above the melting point of aluminum by almost 400 degrees. Granted steel is over 2400 degrees, but just think about that for a second. 1600 degrees, 7.5 times hotter that the boiling point of water.
Its a good thing our valves are not made of water i guess...
If its just a 1/4 mile run I doubt that temp will hurt it
I hit 1600 all the time.... Normal driving when i speed up is over 1200... 16-1800 is not a problem when its only for a few seconds... I run Xtreme race all the time
im new here. what does EGT and WOT mean?
Egt means- exhaust gas temp and WOT means wide open throttle
ahhh thanks. been seeing WOT everywhere and have been sitting here thinking to myself everything and anything that it could have meant.
1 - 19 of 19 Posts
