1 - 8 of 8 Posts
Hi all,
I have a 2012 running Gearhead tunes on SCT X4, no limit block off plates with SCT EGT probe. I live in the Arizona desert and in July when it was 115* + out my EGTs were in the 600s cruising 70-75 and spiked in the 800s when climbing long grades. Recently it has been in the 90s and my cruising EGTs barely spike above 400*, does this sound normal?
I just want to be sure, as I am unsure if the ambient air temp would affect the readings so much.
Dillon
Discussion Starter #2
Also - all of these readings were on the tow tune. I just switched to the Hot Street tune this past weekend, but haven't noticed anything different on the readings so far
Hi all,
Dillon
Sounds pretty damn good to me... If 800* is the hottest you've seen it you've got nothing to worry about... rule of thumb is nothing over 1200* for prolonged periods of time :)
unless your truck just runs VERY cool, i can see over that just getting out of my driveway. 600-900 driving is an average cruising temp
1 - 8 of 8 Posts
