For some reason, last week, my EGT isn't dropping after I park. And it's been pretty cold (for here), teens to 30's. Normally when the temps are cool like that the EGT drops to 350 or less almost immediately after I put it in park.
But now, I'm lucky if I can get it to drop below 450. Another strange thing is that EGT seems to drop lower (to 450 range) while it's in Drive, and if I put it in park or neutral, it will actually start creeping higher?
EGR is deleted, oil cooler has been replaced (twice), did ARP studs and gaskets last summer. It makes no sense to me. I've tried different settings on the heater (defrost used to make it drop slower if I had it on, doesn't work now).
EOT and ECT's are always great, 0-5 degree delta.
Any ideas what it could be? What can I check? I don't want to coke my turbo bearings.
Thanks in advance.
Thanks in advance.
