1 - 7 of 7 Posts
I want to know , what is the best combo for money bettwen limewire and sct x3 + egt gauge . While i'm here do you drill your egt without removing the manifold, and have you done it yourself or you have to go to shop ? one last question do i need more info than the egt to run this truck safely thanks
I went with gauges and xcal3. I wanted analog gauges, not digital, plus I read the livewire display wasn't the most reliable. I drilled and tapped the manifold for the egt with the manifold still on the truck.
lifetime member
welcome to the org. mine will be drilled on the truck for the egt when i get around to doing it. i just run boost for now and both guages are autometer. i would at a minimum run egt and boost. some do tranny temp also. more important if towing heavy.
I have an Edge Insight installed and I like it a lot. I't lets you look at anything the computer sees and allows you to seet up cutom screens you can easilt flip to in case you want tho look at other params.
i have the livewire, but if i was going to do it again, i would do a quad pod fuel press, egt, boost, trans.
1 - 7 of 7 Posts
