1 - 15 of 15 Posts
So for the last week now my truck has been missing and cutting out as soon as I give it half throttle to full throttle and it does it with the SCT plugged in, and on stock too. Last week I cleaned my turbo veins on the inside of my turbo because I thought they may be sticking, and it still didnt fix my problem. Today I took it to Ford, they ran diagnostics on it and said my turbo was fine and said that my EGR valve was sticking. Should I buy a new stock EGR valve, or buy a after market EGR valve plug? Any input would be greatly appreciated. :thumb:
Discussion Starter #2
come on guys I need help quick i have to leave for texas tommaro and have to pull my camper
You could just pull it out and weld it shut...or have it welded shut.
If that fixes your problem then get the plug.
Do I just weld. Up the two openings on the valve or what and then do I leave the connector of
I would just weld it so it cant open anymore once that is done it makes no difference weather its plugged in or not.
I left mine plugged in so I didnt have the loose conector flopping around.
i went ahead and got a egr valve plug from diesel tech1 and it still cuts out sometimes anybody else got anything why she is still cutting out?
If it aint a CAT itsa DOG
Did they check the ICP sensor or the FICM?
Im not for sure on that put ford ran diagnostics on it took it for a test drive and said my egr valve was sticking and said my vgt programming was messed up because of the cold air intake that was on it said i needed to put the stock air box back on it
Most dealers don't like aftermarket stuff. If the truck is actually cutting out then i don't know why it would be a problem with the egr valve. It sounds electrical like a sensor issue that is making it just cut in and out. If it was studdering or smoking and low power i could see the egr valve as the likely problem.
well before the plug was put in i did have low power and studdering but it still does it but nearly as bad or much
Oh ok, have you tried just unplugging the egr valve sensor?
Discussion Starter #12
well now that i have the plug in there it just a solid piece of billet alumnium that replaces the valve so its permently shut and you just leave the senser unplugged now i have good power with the plug in there but it still studders sometimes
Man, i don't know what to say. I know the icp sensor can cause the throttle to jump around, but it doesn't cause a real lack of power. How about your fuel filters? I gotta run now, but just check out some of that stuff. I will get back to ya later man.
Discussion Starter #14
ya thanks for the all the help ill check the icp sensor though
Discussion Starter #15
i have cme to the conclusion that it only surges when the motor is cold and today my tranny shifted like i had the tow haul on does anybody know what this could be
1 - 15 of 15 Posts
