1 - 7 of 7 Posts
As it says will it hurt to only take the valve out for now and block It off untilli get a full delete?
What are you going to block it off with?
You can't just put a cover plate over the hole, that will leave the EGR system open 100% of the time.
I'm going to weld it shut does it take a specile kinda weld or is it steal or what lol? Will a regular welder work?
What he said^^^. Some guys have welded the egr shut and reinstalled, but your gonna get a cel light more than likely
But is the valve a specile medal can I weld it with a normal welder? The valve
Noone has said they had problems welding it that I recall.
Ok thanks I'll use a regular welder then thanks for the knfo
1 - 7 of 7 Posts
