1 - 9 of 9 Posts
i have a 2005 f350 6.0 135000 miles. recently started getting pretty sluggish and after it idles for a while and i take off it blows black smoke thinking egr valve maybe. i was gonna pull it out and clean it but wanted some opinions first. any thoughts?
no tuner my truck is stock probably why i only get 13 mpg i will try cleaning it for sure thanks
You need a monitor, not a tuner, I suspect you have stored codes for other problems with only 13Mpg. Have you checked your oil lately?
cleaning it is hit or miss. If the electronics are failing cleaning won't help.
yes i have but im curious what would oil have to do with bad fuel millage? iv gotten the same millage since i bought the truck. i figured they just suck
Oil can be a huge difference in a 6.0. My truck with Dino oil in it got about 12. When I switched to rotella synthetic it was up to about 15-16.
really i never would have guessed that. new to diesels. what you run for oil i live in northern Michigan and its cold as cold gets here in the winter so i was thinking about running 5 w 40 for winter.
Shell rotella t synthetic. You get it at Walmart.
1 - 9 of 9 Posts
