1 - 7 of 7 Posts
07 f350 6.0 62000 miles. getting tired of taking it in just to have the EGR replaced. last time they cleaned the intake, rebuilt the turbo and other things, 600 miles later its acting up again. I live in Oregon and they say Oregon diesel sucks. so what kind of additive should I use or what can I do to trick the EGR. I heard someone talk about a EGR DELEAT. what is it and what can I do. 503-473-3646 if you wanna call me. thanks Dave
The EGR delete rerouts the coolant from the EGR cooler back into the base engine coolant system. It also comes with a new up-pipe for the exhaust that is straight instead of having a passage for the EGR cooler. They often include a plug that goes in place of the valve and completes the delete. Pretty easy to do if you've ever done an up-pipe and an intake manifold on the 6.0l.
Are you bound by regular smog checks in your area?
I made my own delete kit using the stock egr up pipe and cooler. Look up "My solution for EGR problem", I have pictures showing the work I did.
1 - 7 of 7 Posts
