Using 2 new EGR valve inlet tube gaskets, install the EGR valve inlet tube and the 4 bolts. Tighten the bolts in the following sequence.
Tighten the bolts at the exhaust manifold to 10 Nm (89 lb-in).
Tighten the bolts at the EGR cooler to 10 Nm (89 lb-in).
