1 - 11 of 11 Posts
There are better options out there; I would seriously question that eBay ad... Doesn't have all the pictures-WTH? That kit is supposed to bypass the EGR entirely. There are several folks around here that have bypassed the EGR cooler; some with kits and some without. You might contact Abrannan19.
good deal thanks for the info
thanks! I can probably help ya out
Rice Hunter
Install freeze plug in up pipe and weld EGR valve shut
freeze plugs can come out and into the turbo.
also when doing it that way you create turbulence in the up pipe.
Thats why its best to remove the 'y' not just block it.
with blocking off the egr will this set a code?
blocking off the cooler will throw a code on the 05^ but can be turned off with the SCT
What would you recomend other then the block off plate. im in a 04
blocking it off works fine I think Adam just means the BEST way is to remove one leg of the Y, the part that leads to the cooler.
1 - 11 of 11 Posts
