^^ X2. This is exactly correct. Airdog also makes for much easier filter changes.A wastegate on a stock turbo/stock fuel truck isnt going to do anything but cause headaches. It is for backpressure reasons, would only open at WOT once you got it tuned right, and with Spartan tunes, backpressure doesnt get out of hand so it would pretty much be useless and never open. An airdog is pretty much like studs, not going to add horsepower, but will help keep your truck more reliable as it will keep the HPFP happy with plenty of fuel
My recommendation on these pickups is to keep an eye on the (reliability) prize when beginning any mod process. Something not mentioned much in this thread is drive pressure, and a waste gate kit will help. Some have mentioned the PITA factor on the WG, and some have mentioned studs as the best option. The fact is that turbos run better and more efficient (and result in higher HP #'s) when equipped with a properly setup system.That's the exact answer I have not found. Thanks so much. Retaining stock turbos and may install air dog system later. Just want the truck to be as "bullet proof"as possible. Thanks power stroke forum.
Cylinder Pressure blows gaskets, not backpressure. Backpressure on a VGT setup will vary with boost during normal driving and can see the ratio you described but most tunes now at WOT are pretty close to 1:1 and backpressure does not get out of hand so how will a wastegate help?My recommendation on these pickups is to keep an eye on the (reliability) prize when beginning any mod process. Something not mentioned much in this thread is drive pressure, and a waste gate kit will help. Some have mentioned the PITA factor on the WG, and some have mentioned studs as the best option. The fact is that turbos run better and more efficient (and result in higher HP #'s) when equipped with a properly setup system.
The "system" includes lots of items from exhaust housing size to intake capabilities, but "always" includes some sort of drive pressure releasing mechanism. Ford has used the EGR system, and VGT position as a waste gate of sorts for years now, and well, we like to rid the engine of those items; hence no way of relieving drive pressure.
Short and long of it? It is drive pressure (exhaust pressure), among other characteristics of a diesel engine, that kills head gaskets (DP:Boost ratio can be 3:1 so still think it's boost pressure?) Waste gates are required IMO, and I usually recommend them with any head gasket install. Might as well do the "cab on" WG kit by Elite first and in conjunction with the EGR delete. Find a competent guy to tune the WG, and run GOOD tuning... makes for the best situation for keeping the stock bolts in place. Worse case? Do the HG's down the road, and you'll already have the proper supporting mods in place.
Happy Dieseling!
Controlling DP controls boost. Unnecessarily over boosting these engines causes unsafe cylinder pressures (along with poor exh. evac.) Main point is keeping the turbo(s) in their efficient map will in fact prolong head gaskets by nature. So, proper drive pressures will prolong headgaskets --- by directly affecting cylinder pressure. We're saying the same thing, just differently.Cylinder Pressure blows gaskets, not backpressure. Backpressure on a VGT setup will vary with boost during normal driving and can see the ratio you described but most tunes now at WOT are pretty close to 1:1 and backpressure does not get out of hand so how will a wastegate help?
