1 - 20 of 22 Posts
I know ultimately it will be the same effect but are there any pros and cons to each one? Any help i can get will be great. I am also looking for a lower cost fix due to just having bought a house and my truck is going in Tuesday for injectors and oil cooler.
Just do it, unless you have the rediculous emissions testing, only downside is late model ecm strategies seem to jack with the cooling fan. You may need a tuner to turn off the light.
I got a delete kit for like 150.00 Nice quality too.
2003 F250 6.0L Superduty Lariott
95000 miles
EGR Delete
Blue spring upgrade
Scanguage II
From Autoguide iPad app
I welded the cooler shut for the cost of my time and the wire used to do it. Of couse I was already in there for a turbo cleaning so I paid to have the intake cleaned as well.
I live in Cali, so I tack welded my EGR valve closed, reinstalled it, plugged in a new EGR valve and ziptied it in the engine valley. No EGR gas circulation:thumb: Cheap, easy, and simple to reverse.
So every 2 years for testing, I just pop out the old welded one and put in the plugged in newer one.
Yes I do have a check engine light
Yes my fan works just as it did before
Yes it helped with throttle response (less lag, quicker spool up)
GET MY ENEMA BUCKET BRO!!
so which is better. im thinking of just doing the block off cause i had problems today trying to get truck inspected w a straight pipe :(
In texas?
$1.50 to block the cooler off with freeze plugs that are in my sig... with that in mind, if I had to do it again I would just pony up the cash for the delete because wrestling the cooler & manifold together back into the truck sucked pretty bad while making sure to line the stupid gaskets up.
In texas?
Yea he took it around the block comes back, pulls into shop. Backs out and says it wont pass because no muffler or cat. I was whatever drove off.
Suck, Squish, Bang, Blow!
EGR Delete with a new up-pipe so there is no exhaust flow disturbance caused by the factory scoop in the pipe.
Get this one: eBay.com
Okay now I'm debating between the river city or the eBay link.
Can someone do a tie breaker
It's all the same stuff. It does the same thing, just not as pretty. But you don't see it anyway... so it's up to you.
The only thing I suggest, is 03-04 do not need the egr cooler bypass exhaust pipe, and stay away from the two-piece designs. Other than that, I agree, they all accomplish the same thing.
I read a thread how a guy emailed rcd and rcd said how theres was better because they had a single pipe instead of 2.
Because that eBay is 170 and rcd is 210
It's one piece, not two.
Don't believe the hype, they are just trying to sell you something that is the same!
I did my homework before I bought one. They were all the same, just all nice and polished.
I didn't care if it was polished or not, it's not like you can see it.
But shiny goes faster. :p
i got the ipr gen 2 with the up pipe
1 - 20 of 22 Posts
