I recently just put in most of a sinister delete kit on my 6.4 and I'm so lost now with where the hoses go! Does anyone know of a good video that shows the whole process? Any help would be much appreciated!
If I recall, they go no where. In fact, the kit should have come with some port plugs to plug the water outlet and inlet.
Sent from my LTEVO using AutoGuide App
only several hoses/pipes to be concerned with. y pipe goes into the lowest port. attaches to two hoses one being the hose that leads to the bpttom corner of the degas and the other leading to the heater core. a small hose the runs above the fan shroud connect to the nipple in the degas and thats it. any other hose from the egr system should have been removed. check and make sure all hoses under the hood are plugged in somewhere. correct me if im wrong someone.
river city diesel and flo pro have directions online as well. clayton has a good thread bout them here.
