I have a question for someone that knows Codes.
I had a local shop put an EGR delete and new oil cooler on the truck about 10 days ago. truck runs great, no issues so far. I was told by the owner of the shop that I would need a special tune to turn off the CEL. No big deal, I can live with a CEL. I will just check for DTC's every so often.
Well, I can't stand the CEL. its really buggin me. like OCD buggin me.
so I grab my handy little Actron scan tool to turn off the light. pull the codes and got a P0401, which I expected, but I also got some monitor codes.
Misfire = Misfire
Comp = Comprehensive Components
EGR Sys= Exhaust Gas Recirculation System
now again I would expect the last one, but the other 2 have me stumped.
the Actron website describes monitor codes as
"What are I/M Monitors? I/M (Inspection & Maintenance) Monitors test the operation of emission-related systems or components and detect out-of-range values. "
are the other 2 Monitor codes all related to the delete? or should I be looking elsewhere?
Note: I tried to put the EGR Valve back in place and plugged up thinking that the code would disappear, (the valve can open and close all it wants, but does nothing. engine is happy and so am I. )
doesn't work. must be picking up pressure from somewhere.
No pressure = CEL is my guess.
because the light will not stay off, I'm now looking to add as special tune to the truck to turn off the CEL for EGR.
I would like to keep the stock tune with only the EGR detect turned off.
1. is there a scan tool the will do what I'm asking?
2. will the monitor codes go away also once "re tuned"?
sorry if this has been discussed, I have been searching for a while and have not come across anything this specific. can some one chime in or point me in the correct direction?
Misfire = Misfire
