I put an edge insight in my truck today and had the egt probe installed but all I get is N/A for egt's. Anyone have any suggestions??
The default EGT is not the EDGE EGT for some reason. To get it to work go to setup display, custom display (n), select the number of windows you want, select the position, then select Edge EGT and you should be good to go.
+1 I had to do the same thing
