It goes from something like 1200 to a big fat ZERO.
That was my point. Basically, the point of my post above, was to show you fine gentlemen something. When it goes to the big fat ZERO as you describe, do you also happen to notice the absence of the trademark "6.0L clacking", until it either slows down to engine idle speed AND/OR you get back on the accelerator?
Under the condition described above, the engine is actually "shut down" temporaraily, meaning that NO FUEL is being injected into the engine. Those of you rare manual transmission 6.0L truck owners will probably take notice of this exact same condition, when you are cruising along and decide to downshift to a lower gear. As soon as you engage the clutch (release the clutch pedal) after the lower gear has been selected, you notice the engine RPM start increase, but the "clacking" stop temporarily because under this condition, the engine doesn't NEED fuel, and therefore injection stops at THAT point in time.
